Air Hawks, how close to ridge?
Old 02-07-08, 04:33 PM
slumlordfrank's Avatar
Received 1 Upvote on 1 Post
Is there a "standard" for how close to the ridge the air hawks should be placed?
How about putting a plumbing jack close to an air hawk, and standard there?
Thanks
Frank
Old 02-07-08, 05:11 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
First, what's an air hawk. I'm guessing you're referring to a turbine vent or a Lomanco can vent? The top of the vents are usually anywhere from 12-24" from the ridge. There is no specified minimum distance between vent stacks and ventilation vents. Neither should leak if properly installed.
Old 02-07-08, 10:31 PM
Thanks
Frank
Old 02-08-08, 09:39 PM
I would use a ridge vent or covered box vent,instead of the turbine vent,they simply leak without this optional attachment that requires maintenance(emptying)found on turbine type vent;
\can`t post pic
