New roof questions...
Old 03-06-08, 10:33 PM
E
I had planned on getting vinyl soffit, metal wrapped fascia and new gutters for my house, but the more I got to looking at things I think an entire new roof would be better (sheathing, felt, 30 year dimensionals, etc).
Let me explain. The house is about 45 years old with the original 3/8" spongy, sagging plywood sheathing. The 4 year old 3 tab shingles look awful because of all the sagging which I am guessing is a result of the thin sheathing.
Am I insane for considering having all this done? There are currently no leaks, but I plan to be here a while and adding new gutters, fascia, etc seems like putting lipstick on a pig.
I figure I can get all this done at once an not have to worry for at least the next 20 years.
Opinions appreciated.
Old 03-07-08, 02:09 AM
K
I'm guessing your rafters are 24" center, maybe 2x4 and not all straight either. Then 3/8" would sag indeed.
5/8" tongue & groove sheathing could go on top of the old 3/8", after stripping off the old shingles of course. This will flatten the roof a good deal without adding framing. It is relatively inexpensive, and, if you're going to have guys up on the roof anyway, it takes little time. Like, a day to put all the sheathing on.
I suggest you have the fascia put on just before the new shingles. A drip-edge flashing goes atop that (should) and roofers will want to nail it down into the fascia.
Old 03-07-08, 11:42 AM
W
Received 63 Upvotes on 55 Posts
New Roof
I would tear off the old sheathing for two reasons:
This gives an opportunity to inspect the rafters/trusses and make any necessary repairs.
Also provides a better chance to get the nails for the sheathing into the rafters. Do you live in a high wind area? If so, glueing in addition to nailing may be necessary.
Old 03-07-08, 12:21 PM
K
Good question: Where do you live? If your roof must take heavy snow loads then just adding sheathing to (probably) underbuilt framing doesn't help where needed.
Old 03-07-08, 11:11 PM
E
I live in northern Georgia. We get some high winds once in a while, but nothing big.
I think I am going to go ahead and get the work done. Thanks for the opinions.
Old 03-07-08, 11:35 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
If you are going to stay in the home for a time . Id say for sure go for it all.. Dont forget about the vents in the over hang and up at the ridge . Might put the foam vents in the rafter space there over the insulation. That way you could put more insulation in later iof you want. Make sure they put a metal drip edge on it . Also use the full lenth gutters if you can there. That way no seams in them.
