Flashing Transition two roof pitches
I am building a shed with the main roof is a 12/12 pitch with a porch that ties in with a 4/12 pitch about 16 inches above the sil plate. I have the sheathing installed and now ready to apply asphalt shingles. How should I flash where the two roofs join?
If you can get your new shingles to go under the old properly, then flashing is not necessary - though it's probably a good idea to run flashing under the old and slightly over the new where they join. Flashing is cheap - and, combined with roofing cement, will help ensure no leaks in the future....
