Patching Flat Tar and Gravel Roof
Old 06-02-08, 05:33 AM
K
What is the best way to patch a tar and gravel flat roof. I have a suspected leak were the flashing on a exterior wall intersects with flat roof.
Thanks ...
Old 06-02-08, 07:36 PM
tinner666's Avatar
Bump off thegravel in the suspect area, flood with hot asphalt and 3 layers of felt, spread the gravel back in.
Old 06-03-08, 10:55 PM
use a spud bar to clear the gravel approximately 3-4 "on either side of metal seam,spray asphalt primer on area,and let dry,then use karnak ultra-trowel same area with thin coat,then set 6"fiberglass membrane(mesh),then trowel heavier coat of karnak ultra(ultra is rubberized flashing cement)---after you are sure you have fixed leak,put a very light coat ultra,and reset in some gravel there to protect the flashing cement from the sun
Old 06-09-08, 05:36 AM
K
Tar and gravel roof patch
Thanks for the info ... I cannot get access to a hot tar kettle .. none availble to rent any longer and cannot rent one from a local roofer so rubberized flashing cement appears to be my best option ...
