Water getting into garage wall
Old 07-12-08, 10:26 PM
rayboy55's Avatar
I am having a problem with water getting into my garage wall between the 2 garage doors. It seems to be coming in around the bottom of the wood casing of the garage door frame. I noticed some mold/mildew on the sheetrock between the doors close to the floor. Would caulking around the casing on the outside solve the problem? There is no water coming into the garage itself, just behind the sheetrock. Any help is appreciated.
Thanks, Ray
Old 07-13-08, 08:20 AM
ICB_Railroad's Avatar
sounds good but after you do seal it you need to keep a good eye on it for a while so you know if you dont have a bigger problum.
