Rafter Span question
Old 07-18-08, 07:34 AM
F
Post Rafter Span question
My rafter needs to be 17'4" from LVL beam to wall with a 1 foot overhang. Can someone tell me if i laminate 2x6x8 pieces togehter to achieve that length resulting in a 3" thick solid rafter that is 17'4" will this surfice?
The roof is a 5/12 pitch and I live in New England. It is for a garage.
Thanks.
Old 07-18-08, 10:52 AM
B
The snow load would be a big problem for 2 x 6. I would expect 2 x 10's to be sufficient but would check local building codes before proceeding.
Old 07-18-08, 12:56 PM
2 -18 ft 2x6`s sistered together should be strong enough
Old 07-21-08, 05:40 AM
F
Thanks Roofing god for the imput. Can I go 12" on center with the 2x6x18'ers or is it best to sister them up and stick with 16" on center?
Old 07-21-08, 05:59 AM
Old 07-21-08, 09:18 PM
I would probably use 2x8x18 ft at 16" on center,if you`re deadset on 2x6`s double them up for rigidity/strength at 16" on center-check out that link michael put up !
