Aluminum fascia, vinyl soffit replacement!
Old 09-02-08, 02:47 PM
I need to repair some rotted fascia boards and then recover with brown aluminum fascia to match and brown vinyl vented soffit to match the rest. There is a bunch missing. My question is: Does the fascia come in a standard (already bent) size and same thing for the soffit? Is it pretty much standard size replacement?
Old 09-02-08, 05:18 PM
W
Received 60 Upvotes on 52 Posts
Fascia
Comes in rolls. Rent a metal brake, cut in lengths to fit in the brake, and bend.
Old 09-02-08, 05:47 PM
XSleeper's Avatar
Received 1,699 Upvotes on 1,524 Posts
Fascia cover can be made with a metal break and aluminum trim coil, as wirepuller mentioned. You can also buy preformed fascia cover, which usually has some ribs in it to give it a little more rigidity. The preformed usually comes in 4", 6", 8" widths. I don't believe the 4" has any ribs.
As far as soffit is concerned, you'll need to match the brand and style if you want it to blend in... not to mention the color. You'd think there is one color of brown, but there's slight variation depending on the manufacturer.
