Roof anchor = leaky roof?
HD and Lowes sell roofing safety harness kits that include an a roof anchor which requires removing shingles to install. If I leave the anchor in place permanently am I asking for a leak, considering that here in Western Oregon we get about 100 meters of rain per year? Maybe if I use a bunch of Henry's gooey black roof sealant it'll be ok?
I've got a steep roof and trees that leave sticky residue on the roof even after trimming, so I need to safely access the roof pretty often. Thank you.
If you seal it up with a good caulk like polyurethane not roof cement under and on top it should be fine. Heres some other alternatives.
http://www.samsonind.com/anchorage_connectors.htm
Yes you should be able to see the truss through the plywood joint at the ridge. If not the nails in the wood will be on a truss. Plus you can tell when a nail hits the truss vs just plywood.
