how to install shingles?
Old 09-26-08, 07:21 PM
H
Question how to install shingles?
Im not sure if this is true or not ( I dont believe so,I could be wrong) I was told that you start to shingle from the top and work your way down ,I would think you'd start from the bottom of the roof and work your way up?
Old 09-26-08, 07:58 PM
Speedwrench's Avatar
bottom up, start with a chalk line that will run across the roof so you can make sure the shingles are lined up across the entire roof. you should measure from the top to make sure that the spacing is correct.
life begins when the kids leave home and the dog dies
