How to Repair Nail Through Top of Asphalt Shingle
What is the best way to repair a nail that was put through the top exposed area on asphalt shingle? This was a repaired area which is on a re-roof with a second course. Should I drive the nail and patch with roofing cement? Or remove the nail and redrive the nail under the shingle and patch with roofing cement? Or other method? Thanks
I think the best answer would be to replace the shingle. That said, I 'fixed' one like that on my roof with a big glob of roofing cement.
This can be accomplished a number of ways. Replacing the shingle may be the best way, depending on the condition of the existing shingles. If you're unsure how to do this I can share step by step advice.
Another option would be to drive the nail, perhaps using a nail set and then caulk the tear in the shingle above. Use a high grade polyurethane caulk, not an acrylic or water based caulk.
However a nail pop is perhaps a symptom of a larger problem and while you're up there I suggest inspecting the entire roof. If you have one pop, you may have more. It could be possible the roofers used 1 1/4" nails instead of 1 1/2" nails which are necessary on lay-overs. You may consider removing the nail and measuring it's length.
This area was just repaired and it looks like the nail was mistakenly driven through the exposed part of the single. It does not look like a nail pop. There are no other nail pops.
I'd fix it by removing the nail, pumping the hole full of polyurethane caulk, then installing a longer nail in the same hole and culking again.... most guys will just caulk right over the exposed nail head and call it done.
Ahh that's what we call a "shiner" since the shiny head of the nail can be easily seen in bright sun light.
Replaceing the shingle is no problem so long as he can break the seal of the upper and lower shingle without damaging the upper and lower shingle. This is usually not a problem if the shingles are not 15+ years old. Then the upper and lower shingle should be sealed to the new shingle with a polyurethane caulk to take place of the broken seal strips.
