roofing repair
Old 06-27-09, 09:12 AM
B
roofing repair
I have a ashfault,3 tab roof that has some of the corners curl ing up. The roof is 6yrs old and otherwise in go shape. I have heard from a couple poeple that there is a adhesive you can get that you put under the tap and roll the curled edge down into it. This is done on a hot day so you dont brake the shingle.I have not been able to find this mat. or any imformation on this or any other way to fix the problem. Any help would be helpful.
Old 06-27-09, 12:38 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums. If the lower edge of the shingles is curling, they are failing due to moisture beneath or from a manufacturing defect. If they are only 6 years old, I would contact the installer, manufacturer, or both to see if there is a warranty in effect. You may want to post a couple of pictures of the problem on a site such as photobucket.com and copy/paste the HTML code to your reply post. That way we can see what you see and could offer better help.
