Angle of roof
Old 01-31-10, 08:20 PM
R
Angle of roof
To all you kind people:
I am going to build a building that is 62' x12', with one roof. how do I calculate the angle at the peak of the roof, so it encapsulates the whole building? John
Old 02-01-10, 03:54 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Use the Pythagorean theorem. You know the base of the triangle will be 6', and the overall rise will be ?? feet. (6 x 6) + (? x ?), then take the square root of the answer, then add the overhang, which is usually 12 to 18".
For instance, you want a 8:12 pitch, your calculation will be (6 x 6) + ( 4 x 4) or 36 + 16 =52. The square root of 52 is approx 7'1". Add your overhang of 12" and the rafter will be approximately 8', taking into consideration the thickness of your ridge beam.
Old 02-01-10, 11:20 AM
W
Received 65 Upvotes on 56 Posts
Angle
Tell us the roof pitch and we can tell you the angle.
Is this a gable, dual pitch roof or single pitch shed roof?
Old 02-01-10, 12:28 PM
R
Question gable, dual pitch roof or single pitch shed roof
Could someone go thorugh each of these: gable, dual pitch roof or single pitch shed roof? This is going to be a single shed roof! I am loking for peak angle! JohnBeer 4U2
