Trying to match shingle replacements
Old 02-19-10, 05:52 AM
Received 1 Upvote on 1 Post
I need to replace some shingles but I'm finding the the color I need is not available in stores in the type I need (laminated type like OC Duration). I can find a pretty good color match in three-tab. I have a few questions.
1) Do the two types intall differently, i.e., can the three-tabs be mixed in with laminated? It looks like the individual sheets are the same size . . .
2) Will the three-tabs look really wrong if mixed in? A couple of the patches that need replacement are fairly large, like 6'x2'
3) Are ridge shingles substantially different between the two types?
4) Do I have other alternatives for finding small quantities of exactly what I need than poking around Lowes and Home Depot?
5) I have no idea what brand they are. Does it matter for replacements? Are the sizes standard?
Old 02-19-10, 07:45 AM
Tolyn Ironhand's Avatar
Received 868 Upvotes on 731 Posts
Getting ready for the summer eh Suobs?
I'm am not a roofing pro but I have worked with both types so here I what I know (or think I know):
Yes, they are both the same size. The laminated will be thicker due to the lamination
I think it would look pretty bad.
Not sure on this one. Most cases I would just cut the 3 tab apart and use that for the ridge cap.
Go to a full service lumber yard or shingle supplier. They will carry more options. If you can, bring a sample.
The sizes are standard so if you can get a good color match, I think you will be ok.
Old 02-19-10, 08:05 AM
You got it: summer = hurricanes.
Old 02-19-10, 08:20 AM
I gotta say, this has got to be the most aggravating DIY exercise I've been through in a while - trying to find the color and order it.
