Air tools on flat roof
Received 0 Votes
Hello, Have a flat roof in bad shape. I'm going to rip off old roof and install 3/4 ply and felt and rolled roofing. I have 2 questions???
Can I use an air stapler to fasten the felt to the plywood???
Can I use a Air roofing nailer to attach the rolls???
Thanks for your help, I've only done shingle in the past and I can't find any information on this on the internet!!!
A stapler will usually blow the staple right through the felt, or foot traffic will rip the felt off the staple. A roof nail will have similar results but has a little more holding power. What you need to do is get yourself some tin cap discs, which you can shoot down with a staple gun or roof nailer. You just hold the metal disc and shoot it down. It increases the holding power of the fastener.
image credit: hardwarestore dot com
But you say the roof is "flat". Some areas do not permit rolled roofing to be used on slopes less than 1:12. For instance, notice the installation instructions for Owens Corning's product. If your roof truly is FLAT, you need a different roofing system.
