Painting Asphalt Roof
I am about to change the color of my house to a color which will be incompatible with the white roof. The roof is in good shape and I would like to change the color to black. I have used a Black Jack roof coating for sealing other roofs and find it very good, but it dries to a semi gloss finish. I would like soemthing that dries to the flat finish expected on an asphalt shingle roof. Any suggestions?
Welcome to the forums!
I don't know about changing the color that much but you can 'color' an asphalt shingle roof with thinned down latex house paint.... and I do mean thinned down - without about 3-4 gallons of water per gallon of paint. The idea is to mist the roof with the thinned down paint. As with any spray job, care must be used to not let the overspray go where it shouldn't.
That is probably what I am looking for. As I said, I have used a Black Jack "latex" roof coating on other property I have. This seems to apply easily and stand up well. My only objection to it is that it has a "semi gloss" finish. I am looking for a product that would dry "flat".
Last edited by GregH; 04-25-10 at 09:58 AM. Reason: Remove advertising from banned member.
I notice that Behr sells a "roof paint". The local dealer for that is Home Depot, that is not where I would go for advice. Has anyone here had any experience with it?
I have used similarly compounded "latex" roof sealers previously on asphalt roofing, with good results. They seem to adhere nicely and retain their color, black.
I would consider thinning one of those (water), but they dry to a semi-gloss.
Behr is supposed to dry to a flat finish, I was hoping to hear real world experience with it.
I've used elastromeric coatings before but not with the Behr brand. Mostly I've used the type that helps to waterproof exterior masonry. I have used a little of the roofing elastromeric but it was applied as part of a roofing process involving a membrane laid down in between coats. I've never used any on asphalt shingles.
All the elastromeric coatings I've used have always been a white base. Can it even be tinted enough to give a black finish?
The stuff is sold at Lowe's, at least locally.
