Cutting through joists, what saw?
Old 05-09-10, 07:17 AM
T
I have a three story (three level) porch which has been reconstructed several times in the last 100 years. It is a mixture of "modern" and "full dimension" lumber. The fir decking is nailed into the joists.
Most of the joists are 2 x 6 on ten foot spans. I would like to reduce the spans to five feet by cutting the joists and inserting more hanger joists.
Can anyone recommend a saw with which I can cut through the joists without cutting into the decking.
Old 05-09-10, 07:37 AM
B
Received 47 Upvotes on 43 Posts
I have a blade for my saber saw that is extra wide, all to the front, so it cuts almost flush. I assume you are installing a new beam recessed up into the existing joists, just make sure the load on each end is properly supported and you use adequate temporary support.
Bud
