roofing beam rot
Old 08-08-10, 06:05 PM
T
roofing beam rot
I have at least one roofing beam 2x8 that has its overhand rotted. Do I need to replace the entire beam or is there a means of "splicing" a 6" section from the inside of the garage to where it overhangs the bearing wall outside? The rot does not extend very far inside the house
Old 08-10-10, 06:40 PM
P
Temporarily Suspended
Beams really don't get spliced. If you want an easy way out, sister the beams on either side of the rotted beam & remove it.
