Gutter cleaning tool recommendations
Old 08-31-10, 08:45 AM
B
I'm looking for a safe, effective way to clean my gutters without getting on a ladder. I've searched the internet including YouTube, where there seem to be a variety of devices that use a garden hose, or a shop vac, one that is a robot and a couple that attach to the end of a pole. (The one from worklesstools seems pretty cool). Does anyone have any experiences or recommendations pro or con for any of these methods? I'm not interested right now in installing gutter guards.
Thanks.
Old 08-31-10, 09:15 AM
Received 1,262 Upvotes on 1,203 Posts
Not sure what it's called but the one I like is a hose attachment shaped a little like a shower head - you hold it over the edge of the gutter and it shoots the water out with enough velocity to clean the crap out of it
Works great but wear a rain coat and hat when you use it
Old 08-31-10, 10:56 AM
Received 824 Upvotes on 722 Posts
20+ yrs ago a friend of mine took some water pipe and a couple of elbows to extend his water hose so he could flush out his gutters from the ground [he was getting too old for ladders] It worked well. 10 or so yrs ago I saw some commercially made attachments that basically did the same thing. The also make one that hooks up to a pressure washer but I'd think you'd need a heavy duty rain coat and big hat
Old 08-31-10, 11:44 AM
R
Another option . . . some leaf blower mfgs. such as Stihl and Echo make tube attachments for this purpose. These work fine when the gutter and debris are dry; otherwise, the air plasters wet stuff above gutter that then has to be hosed off.
The type Mitch 17 & marksr also work well. I made one from PVC pipe, and then found an irrigation spray head to attach to a U-shaped end. While not doing it yet, Ive thought about making a horizontal support plate, perhaps w/ small wheels or a fiberglass L, so that this device could rest on top edge of gutter and slide along it w/o scratching the paint.
Old 09-03-10, 10:21 AM
B
Thanks for the comments. After looking at what's available out there I think I'll try out that gutter cleaner from worklesstools.com. It looks pretty easy and you don't need a garden hose or a shop vac. I definitely don't want to invest in gutter guards just yet.
