Installing Gable Vent - Wood Cedar Shake Siding
Old 09-30-10, 11:28 AM
F
Hi all,
I'm refinishing my garage and would like to install a Gable Vent to vent the small area between the cross joists and roof before I sheetrock. Should I take off the shakes outside one by one, install the vent then reinstall the shakes? Or, should I lay out my template on the inside sheathing, drill holes in each corner, run a chalk line corner to corner then use a circular saw to cut-out the hole from the outside?
Thanks
FC
Old 09-30-10, 12:02 PM
badeyeben's Avatar
It depends how careful you measure and cut. If I were doing it I would remove plenty of shakes, cut the opening and install the vent. Then when reinstalling the shakes you can do a nice job on reinstalling them. No chance for a messed up cut and having to buy new shakes that won't match to repair the damage.
Old 09-30-10, 12:05 PM
W
The easiest way is probably just cut out the opening and shove in the vent.
However, I would carefully remove the shakes and then cut the opening. That will allow you to weather flash the area around the opening. I would also frame the opening on the inside to provide a solid nailing surface for attaching the vent. It also provides a flat surface for the vent flange to sit on.
After the vent is in place you can caulk around the vent and replace the shakes.
