How to insert replacement T & G 2 X 6's
Old 11-05-10, 07:53 PM
I
It seems to me that the only way to replace bad tongue and groove 2 X 6's is to cut off part of the tongue of the new piece until it will squeeze in there. Right? (This assumes that you cannot slide the new piece in from the side)
Old 11-06-10, 03:20 AM
Received 840 Upvotes on 737 Posts
You would cut off the bottom portion of the groove [not the tongue]
Old 11-06-10, 05:19 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
And you would only need to do this on the last board, if you are replacing more than one. Cutting the bottom part of the groove piece and possibly camfering the edge will allow you to engage the tongue, then drop the board in where you can face nail it for security.
Old 11-06-10, 11:57 AM
I
Cutting off the bottom groove would make that inconsistency visible from the inside. I have an open beam ceiling.
Old 11-07-10, 10:54 AM
W
Received 63 Upvotes on 55 Posts
Tonge and Groove
Is this for roof sheathing? If so, you could do the reverse of what Mark suggested; before installing the last board, cut away the top of the groove on the adjacent board which is still in place. This will allow the tongue of the last new board to fall into place with no noticeable difference from below.
Old 11-07-10, 12:46 PM
chandler's Avatar
The more information we get, it seems to get more complicated. I'll bet it is like my former log home. The second floor was 2x8 t&g, exposed top for the floor, and exposed bottom for the ceiling. We'll wait.
Old 11-07-10, 01:47 PM
I
Simple. Sounds like the way to go. Thanks!
