Leaking built up roof
I've been using "Kool Seal" brand roof cement. I don't like it . It dries soft and spongy. I want something tougher. I need white. Any ideas?
HELLO
Kool Seal is a good product have been using it for years.
For any sealer to work you must properly clean and remove the build up of old sealant make sure the leak can be repaired with the kool Seal, it may be that the roof parts are moving and need to be nailed better before you put the Kool Seal on. As with all Job you need to do it right from the start to end to make a finsh job of it....
