HELLO
Heat tape is realy the only one I have found that works and you can control easly..Just plug it in or install a switch
take very little electric and can be installed most every were.. Check it out..
How can I stop water leaking under a door? DH has tried numerous things on the outside such as concrete, roof calk, silicone calk. When the room was built, bottom plate is treated and calked prior to installation. Door is plumb. Water leaks either underneath or to the sides and all over the floor. Now with winter here, air can be felt, as well as I have had bugs, worms, you name it, it gets in. Should I calk from the inside? I am afraid there is lots of water damage being caused on the inside of the wall. What can I do? Sidewalk may not be sloped correctly. It is approx 3 feet from door and flower bed after. Read More
