Water in basement. Runoff or not? Want to use dye.
Old 04-04-11, 10:30 AM
I've lived in my house for 3 years and the past 2 springs have had a fairly significant amount of water seep in through the bottom course of block and through the floor up around my effluence pump.
It is not a huge problem so I am taking a methodical approach over time to find the source of the water and rather than tear up my entire yard and/or install some kind of system inside. The basement is walk-out so the water flows in a sheet about 1/4" "deep" and runs out under the door jamb. Also the water is clean so clean up is basically a fan for a few days.
I am trying to find out if the water is from runoff, from some kind of underground river, or rising water table.
I think it is runoff, the yard in the area of the main water entry is not graded properly.
I was thinking a way to test this would be to put some sort of dye in the area of the poor drainage I suspect and see if I can detect it in the basement. My concerns are that the dye will ruin my basement floor, and could find it's way to my nearby well. Does anyone know of a non-toxic product that would work? Or have any tips or suggestions on how to tell where the water is coming from. I was thinking to buy a ton of tonic (with quinine) and pour in on the ground and go down there with a black light the next morning....
Thanks,
Mike
Old 04-04-11, 10:41 AM
Received 1,262 Upvotes on 1,203 Posts
Turn on the garden hose in the area where the water is coming in and see if that reproduces the problem
Old 04-04-11, 11:00 AM
Actually I had not thought of that! But it usually only happens from a LOT of rain, like 3-6" in a 12-24 hour period or so. Takes it awhile to get going, and then awhile to stop, maybe 12 hours lag from the rain starting and stopping. I don't know if I could put that much water on the ground with the hose. I meant once the water starts inside I could throw some tablets on the ground. Thanks for the tip, I may try it. Can't hurt.
