Flashing and waterproofing covered balcony
Is the garage ceiling the balcony roof? What type of sleeper set up do you have and is the roof properly sealed? Maybe posting a few pix would help us to see what you see. Flashing is definitely a good starting point, but there may be other issues we can help with. http://www.doityourself.com/forum/el...your-post.html
Sorry it took awhile to get back to my post as I was away. The balcony floor is actually the front portion of the garage ceiling, and a walk out from the master bedroom. Here is my plan. You can have a look at the pictures in this post and tell me if I'm on the right track. As in my previous post, I have removed the flagstone floor, and cut back the stucco (that originally went right to floor level) up 6" from the floor to expose the tarpaper which I cut to 2" below the stucco. My plan is to sand the existing floor and to use a leveling compound to fill any gaps and screw holes in the plywood. Then I was going to sand the filler, and make the floor smooth and level. Next, my plan was to install cant strips along the entire perimeter of the balcony to create a runoff to a center drain. Once the cant strips were installed, I would then do 3 coats of kavlar (liquid rubber) up to just below the tarpaper on the perimeter and also on the entire balcony floor, reinforcing any large gaps and inside corners with kavlar and geotextile fabric for strength. Once dry, I should have a little better than 1/8" thickness of the liquid rubber. Then my plan was to lay in Duradek, or Deckmaster vinyl sheething on the deck, and also have it go up the perimeter walls to almost the tarpaper. Then apply new tarpaper under the existing tarpaper and over the Duradeck to just above the cant strip. From there I was going to install stucco stop to just above the cant strip, and then do a brown coat, scratch coat and finally stucco. I think this would give me a fairly dependable seal, but I want to make sure that I'm on the right track. Here are the pictures of what I'm dealing with. http://s1198.photobucket.com/albums/aa441/shermar104/?albumview=slideshow[/URL]
