Closing a flue
Old 10-08-11, 12:23 PM
Closing a flue
I have a chimney with 2 flues for 2 fireplaces that we never use. In the winter these just leak cold air. I've tries blocking the top of the fireplaces where the doors to the flue are with plastic, covering the fronts with plastic (which worked pretty well last winter).
This year I want to try getting a single roofing shingle, cutting it into 2 pieces a little larger than the flue opening on top of the chimney outside (to make a seal) and then putting 2 square concrete patios bricks on top of the shingle cutouts.
Any thoughts?
Old 10-08-11, 05:08 PM
Received 824 Upvotes on 722 Posts
I don't know about the shingle, it seems to me that would be something that could accidentally fall into the flue although I see quite a few that use a masonry block over the top. I'd use a bead of caulk for the seal. Ideally you use a metal cap that would come down the sides.
Old 10-08-11, 05:19 PM
Thanks. Good to know that others are doing the same thing.
Old 10-08-11, 07:32 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
Perhaps a silly question, but you do have both dampers (above the smoke chambers) closed, yes? A few years ago I fabricated a snug-fitting flue cover with a handle on it, out of scrap steel. Easy enough to remove when necessary, but heavy enough that it never blew around in a stiff wind.
Old 10-08-11, 08:10 PM
Yup, dampers are closed. One year I even made a wood frame to fit snug at the top of the fireplaces right under the damper with plastic and insulation and more wood and it still leaked - but that was in the dead of the winter and I wasn't going up to the chimney. Sounds like I need your flue cover. If the concrete block works, I'll make something more permanent next year.
Old 10-18-11, 08:05 PM
E
I don't remember the name, but I saw it on one of the many home improvement shows I watch. It looked like a square inner tube, you stuck in the flue, and pumped it up to seal off the flue.
