Tin roof
Old 04-05-12, 12:31 AM
E
Received 6 Upvotes on 6 Posts
Tin roof
I am having a 25' x 12' addition put onto my house and because of the low pitch of the roof I decided to use ridged tin. I know I will have to prime and paint the tin when finished so I am asking for suggestions as to what material I should use to do the job. Thank you.
Old 04-05-12, 07:03 AM
Received 800 Upvotes on 703 Posts
What type of tin roof needs painting when new?
The 2 basic metal roofs available today either come with a factory finish or are galvanized. Generally it's best to let a galvanized roof weather for a year or so before painting.
Old 04-05-12, 01:40 PM
E
The product is called Terne II and it's architectural roofing material. It comes as flat stock and it must be formed with a brake. The roofer told me it should be painted after 30 days curing and I'm looking for the best idea to do it.
Old 04-05-12, 02:26 PM
Does the manufacture having any painting tips?
There may be an oily film on the metal, if so it should be washed off. Generally metal roofs are primed/painted with oil base. If the metal is thin enough to have much expanding and contracting, oil base coatings might peel. If that's the case it might be better to use a DTM paint [direct to metal] The better paints stores would have it. It would be best to contact the roofing tin manufacture and get their advice!
Old 04-05-12, 02:36 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Found these pages from the mfg.
Terne II® - ZT® Alloy Coated Steel | Follansbee Steel
Rapidri® Paint System for Terne II® - ZT® Alloy Coated Steel | Follansbee Steel
It sounds like they have a specific primer and paint in mind and a specific maintenance schedule (repaint every 8 yrs) if they are to stand behind their product warranty.
