Drip Edge
Old 05-18-12, 10:45 AM
F
Drip Edge
My roof is asphalt 3 tab shingles, and the shingles extend past the fascia and over the gutter. The drip edge is not the typical T shape and is a simple L shape that drops down flush against the fascia board with a little kick-out at the bottom edge. Is this OK?
Old 05-18-12, 12:14 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Thats actually the most common type of drip edge I've seen. If installed correctly (as well as the rest of the roof) it shouldn't be an issue. It's what I had back in VA and it was fine.
I used the T type when I did my neighbors carport...but it's roll roofing with a very slight slope. I just wanted a bit more support at the edge...plus it was the only one available with the larger leg that attached to the roof.
Old 05-18-12, 12:57 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
The L-shaped flashing you have is called "gutter apron" and is the correct flashing to use above a gutter, since it has a long downward bend to flash the top of the gutter, but it is not really an "L" since it is bent at roughly a 20° angle to account for some of the roof pitch. The other common kind of drip edge is called 5" d-style, and it is usually used on the rake or gable end of the house. The downward bend on 5" d-style is not sufficient to cover the back edge of a gutter since the gutter will usually drop below it's 1" downward bend. 6" d-style has a longer downward bend and would probably be okay to use over a gutter.
In some parts of the country "gutter apron" isn't commonly used. I guess those people must be used to having their gutters leak.
Your shingles should never extend more than 1" past the edge of your flashing. IMO 1/2" is plenty. I like to let the starter hang over 1/4" and the shingles another 1/4". But if the roof edge is really crooked sometimes you have to let it hang over more to get a straight line.
Old 05-19-12, 08:32 AM
F
Thanks guys...I learned something today!
