ShedLight Roof Vent Installation
Old 10-06-12, 07:15 PM
A
I bought 2 of those for my shed
Duraflo > DURAFLO
http://www.duraflo.com/Portals/0/Pro...ct%20Sheet.pdf
I haven't shingled the roof yet should I shingle the roof first then cut the whole like it says in the instructions or cut the hole now and shingle around?
If I install before installing the shingles I won't have that lip at the bottom I'm wondering if that could be a problem for water.
Old 10-07-12, 03:24 AM
chandler's Avatar
Received 5 Votes on 5 Posts
Shingle up to the bottom of the hole. Install the skylight/vent and continue shingling. That way the bottom of the vent will overlap the shingle at the bottom of the hole. Be sure to seal under the flap of the vent when you install it with Henry's or an elastomeric sealant.
Old 10-07-12, 08:49 AM
A
Great idea Thanks
Old 10-07-12, 08:53 AM
A
Is that lip at the bottom crucial for the water to drip? The bottom lip under the shingles would look much cleaner but I don't want to have water problem in the long run.
Old 10-07-12, 09:53 AM
chandler's Avatar
It would look much cleaner until the wood began to rot and it fell through Water has to shed off naturally.
