Need urgent help- downspout into conduit
Old 10-08-12, 08:54 AM
T
Hi folks,
I have a downspout going into a conduit drain under my driveway. However, I've learned this drain pipe is not connected to anything. The downspout goes into a 2.5"x 3.25" rectangular insert that goes into this condition pipe. I want to "cap" this insert off. I cannot find a cap inert to fit inside the 2.5"x3.25" opening. Does anyone know if a cap like this exists? I'm trying not to pour concrete in the conduit to cover up, but may have to if I cannot find a cap to fit
Any feedback will be appreciated
Old 10-08-12, 09:14 AM
P
Received 600 Votes on 554 Posts
Not sure how capping a old downspout is urgent but... I do not know of caps to seal off downspouts. If you want to cap it I'd stuff rags in to plug it and leave about 3" at the top to more permanently seal it off with concrete or mortar. You could also make a cap out of vinyl siding trim stock material or use aluminum flashing.
Old 10-08-12, 09:37 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Possibly you simply have a tile adapter. Simply remove it and find the correct size cap.
Old 10-08-12, 11:10 AM
T
The tie adapter is exactly what I have. Didn't know the name. Unfortunately, the pipe didn't extend past the driveway. Therefore, the top lip of the adapter is even eith my driveway, meaning concrete poured around it. No way to remove it. This is why I'm wondering if there is an insert to cap it
To the other poster, it's not the downspout I want to cap, but the tie adapter. It's urgent as every time it rains, the water goes into the conduit (which is connected to nothing) and water has dropped that corner of my porch by 1/4". My downspout is now extended to the grate drain at the end of my porch, but water running down my driveway is still running into the tie adapter and into the drain
Old 10-08-12, 11:31 AM
lawrosa's Avatar
Super Moderator
Best your going to do is measure the dimensions and e mail a place like this to see what they have.
Rectangle, Square, Round, and Tubing Plastic Pipe Plugs
I would need to check if fernco makes something
