building a wooden room on top of a concrete building
Old 02-09-13, 05:22 AM
first of all sorry i really didnt know in which section i should put my question , im wondering if its possible to build a wooden room on top or already existing building? why i want to do this is because where i live jordan middle east you are allowed to build only 25 square meter but if i used wood you can do it as big as you can
Old 02-09-13, 05:39 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Welcome to the forums! As you guessed it it a primarily a North American site, so we have no idea what the building codes/practices are going to be in the Middle East. The availability of wood in your area may pose a problem as well. In our area, you first must enlist the help of a structural engineer to determine if the existing structure will withstand additional floors. Very important or you could end up with a pile of firewood. The roof will need to be removed, structural joisting installed, then framing can take place. Very complicated. Check with an engineer first, and good luck.
Old 02-09-13, 06:02 AM
The wood is not a problem .I have to find a structural engineer
,but the thing is that if im going to ask for a help from an engineer
it will cost money even if he just came and took a look for like 5 minutes
so i just wanted to know if its possible to build a wooden room
on top of a concrete building that is built to withstand an additional concrete
floor so i think it will be able to handle a wooden room
Old 02-09-13, 06:05 AM
Received 138 Votes on 123 Posts
How do you know that the building is able to withstand an additional load?
I assume it has a flat roof ??
Old 02-09-13, 06:07 AM
because when we build it to withstand an additional floor since the regulation are changing which is another reason why i want to build a small wooden room . because if the regulation changed and they would let us build another floor .
its a flat roof yes
