Water in Basement When It Rains
Old 04-11-13, 07:08 AM
D
Question Water in Basement When It Rains
I get water in my basement when it rains. Not everywhere, just in certain rooms. Just water on the surface of the basement floor, it does not rise or move into all areas of the basement nor does it cover the entire floor in any room.
1) The yard does not slope away from the house enough.
2) I don't know whether there is a drainage pipe underground or not.
3) One corner of one room in the basement seems to get particularly wet from top to bottom. That's where the water was this time. In that corner, there was a little hole chipped out of the wall at the floor level. Someone told me that was put there on purpose so the water can drain out of the wall instead of sitting in the wall.
I want to fix it right the first time so this doesn't happen anymore. I want no more issues with water in the basement. What should I look at or look into first, second, third in order of priority to troubleshoot the problem? What should I look for? When I find what the problem or problems are, what should I do?
Old 04-11-13, 07:55 AM
Received 1,186 Upvotes on 1,144 Posts
First step is move the water away from the foundation in the first place with grading, gutters and downspout extensions. Since you know where the water is coming in, you can also dig those areas out on the outside of the house to address cracks and holes and such. Not a small job....
Old 04-11-13, 07:59 AM
D
Tell me more about grading. Do you mean sloping the yard so water naturally moves away from the house?
Old 04-11-13, 08:00 AM
Yes, grading the area around your house so it all slopes away from the structure. As I said, this is not a small job.
Old 04-11-13, 08:13 AM
N
Received 20 Upvotes on 18 Posts
Before digging, how old is the house?
Mitch pretty much covered everything I would have offered.
Grading would be to have the ground at or near the house to slope away from the house.
Gutters are also a huge help. If you have leaking gutters or none in that area, all the water coming off the roof is falling to the ground, right at the house.
Old 04-11-13, 08:27 AM
D
If I decide not to do this grading myself, what might it cost to have done?
Old 04-11-13, 08:32 AM
N
That is really hard to guess from the internet. The local labor costs, materials and scope of the job will determain the cost.
Old 04-11-13, 08:59 AM
I had a neighbor who had water getting in along one spot along the back of his house. Quite a bit of grading was required throughout the yard to change the flow of water off the hill behind his house and he told me the total cost was $6K.
As Mike said, your best bet is to get a few contractors on site to bid the job so you can compare.
