Gutter guards , Do they work ?
Old 04-29-13, 01:33 PM
G
I want to install gutter guards on my gutters but I've read some mixed reviews on them ( They work & They don't work ) what are your thoughts ? Could you recommend a brand or style if they worked for you .
Old 04-29-13, 03:47 PM
Received 98 Votes on 86 Posts
My parents installed Gutter Helmet about ten years ago after the old man fell off while cleaning the old ones....
They've been good, the only issue is a spot where someone stepped on one and crushed it a bit, it doesn't carry the water into the gutter in that spot as well any longer.
Old 04-30-13, 04:39 AM
Received 422 Votes on 377 Posts
They work better for leaves than they do for pine needles but overall they do a good job.
Old 04-30-13, 05:17 AM
G
They look like they'll do the job,I wonder how well they do in a heavy rain, what I mean by that will the rain roll past the opening ? Thank you for your replies.
Old 04-30-13, 10:17 AM
The only problem with Gutter Helmet I've seen in any rain is the spot I mentioned where one of them is damaged.
Old 05-06-13, 09:27 AM
R
GutterBrush Gutter Guards work well
We have had a good experience with a simple do it yourself product called GutterBrush. Basically a big bottle brush that fills the space inside your gutters and lets water flow through while blocking most leaves, etc... Heavy loads of Pine needles and small debris may require some limited cleaning or maintenance, but worth your consideration.
