Trying to stop a wet basement.
Old 06-17-13, 07:32 AM
After my second time of shop-vaccing 80+ gallons from my basement, I finally had a friend help me with my gutters. I kept this project simple; simply installing inside miters and using slip joints connectors to make a better seal. Unfortunately, 20 foot roofs, 26 foot multi-purpose ladders, and acrophobia caused me to neglect running a final bead of sealant on one of the connectors and I still have a bit of a leak. At least I hope that's why. Otherwise that gutter is sloping the wrong way and I need to find a way to install new gutters. But I digress.
While I was up there, I noticed that the gutters were the kind that come with hidden hangers with straps pre-installed. Not that this is bad, but whoever did the roof last apparently laid plywood/osb/whatever on top of the straps, then put down a drip edge, and then shingled. Will this, in and of itself, cause water to get anywhere it shouldn't be?
The next issue for my basement is fixing the grade. I live in a rather flat area and have almost no side yard;
1) What is the "proper" soil to get to put around the foundation to build it up?
2) Is there a good enough option I can use so I can put plants on that one side yard instead of grass so I can ignore it later instead of mowing and trimming?
3) Any other suggestions?
Thank you
Old 06-18-13, 02:38 PM
Temporarily Suspended
Before you throw any dirt there, inspect the foundation for cracks, however thin they may be. The foundation may require a membrane that goes to the footing.
