Cracked, Leaking concrete roof repair recommendations?
Old 09-14-13, 09:28 AM
N
Question Cracked, Leaking concrete roof repair recommendations?
So, what I've got here is an old root cellar about 7' X 7' square. It has a flat concrete roof with a ~5" curb on three sides (I suppose to make water run off the un-curbed 4th side). There are several cracks in the roof, up to maybe 1/8th inch wide. I'm kicking around ideas for repairing the cracks to make the root cellar dry and usable again. I'm considering- Elastomeric roof coating, Rubber roof (pond liner), Concrete (cement, mortar?), Epoxy (like used for boat repair/construction, pour into the cracks). The roof is visible for the higher back yard and a wooden deck may be built on top of it for aesthetic reasons.
Any thoughts on the above or other/better ideas are appreciated.
TIA
Neo
Old 09-14-13, 02:26 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
I would probably experiment on a crack using a self levelling concrete sealant. if its too runny and wants to run into the cellar... patch the ceiling inside with a vinyl patch repair mortar. the self levelling sealant will run down into the cracks and seal them up better than anything you might try to apply to just the surface.
Old 09-14-13, 08:10 PM
N
Xsleeper...
Thanks for the input!
