leaking T & G roof
Old 10-26-13, 10:14 AM
leaking T & G roof
I have an older bungelow built in 1941 with a T & G cedar roof. Of course the boards have shrunk and I'm getting leaks where the shingle nails have come thru in the gaps between boards. Is there any material I can apply from inside the attic, into the gaps to seal things until I can do a proper fix in the spring?
Thanks
Mike
Old 10-26-13, 11:43 AM
F
Received 35 Votes on 27 Posts
Nothing applied from the inside will be effective in stopping the leaks. Sorry.
Old 10-26-13, 01:28 PM
Received 300 Votes on 266 Posts
Welcome to the forums Mike!
Inserting some caulk on the inside might help a little but the gaps in the roof decking aren't the reason for the leaks. Have you been up on the roof to inspect it?
Old 10-26-13, 01:45 PM
P
Received 599 Votes on 553 Posts
Also stopping the leak on the inside means the wood of the roof above is getting soaked which will cause rot and in addition to needing roof shingle repairs, you will also have structural problems.
