water leak from either wall or roof into my bedroom
Old 11-05-13, 11:58 AM
noticed the water leak in my room. do I have to remove the dry wall? thanks.
Old 11-05-13, 12:01 PM
Received 62 Votes on 58 Posts
Welcome to the forums.
You have to find out where the water is coming in and that often involves removal of at least some of the drywall.
Old 11-05-13, 01:19 PM
Received 316 Votes on 290 Posts
You could also try to identify the source of the leak from outside. It's most likely a problem on the roof though the wall is a possibility. It also could be anything above containing water like a HVAC unit with a leaking catch pan or a leaking plumbing line.
Old 11-05-13, 02:02 PM
Received 168 Votes on 149 Posts
Is the stain on the ceiling? If so, can you access the attic to investigate further? If an exterior wall - check around windows and/or anything else that goes thru the wall. It isn't a big deal to patch drywall but I wouldn't start by cutting a hole .... save that for last. Pics might be helpful - http://www.doityourself.com/forum/el...-pictures.html
