Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Roofing, Gutters and All Waterproofing Anywhere
Reload this Page >
Is it possible to attach a gutter to a roof that has no fascia?
Old 04-16-14, 11:35 AM
Received 1 Vote on 1 Post
There is this house I am not sure how the soffit was constructed, where normally you would have fascia wood boards behind the drip edge, it is a rounded bottom. Hard to explain but here are some pictures.
How would you install a gutter along the front side of this roof?
Old 04-16-14, 01:56 PM
Received 241 Votes on 220 Posts
I think the bigger issue is the lack of overhang to get water into a gutter. Were you planning on sliding the back edge of a gutter up under the corner flashing/drip edge?
Old 04-16-14, 06:25 PM
Norm201's Avatar
Received 77 Votes on 71 Posts
There are many types of gutter systems that don't necessarly need to be hung on the sofit. Do A Google search (images).
You could go with the type of gutter that is a vertical riser (if forget the name of this type (line pole gutters??)) near the edge of the roof slanting towards one end. It will direct the major runoff of the large roof area without the traditional gutter hanging off the soffit.
Something like this.
Old 04-17-14, 09:41 AM
Pilot Dane I am not sure what my strategy would be.
One thought would be to remove the end row of shingles and attach a longer sloping drip edge. But still I can't think of a way to mount a gutter.
Old 04-17-14, 09:45 AM
Norm201, interesting. This is more like a dam. I have what some called a dutch gutter in one of my houses, which is an integrated gutter system within the roof structure. In such a gutter the framing was done to provide a sloped channel from one end to the other.
In this illustration above, I am guessing the dam is mounted such that one side is further up the roof compared to the other side to provide a slope? Otherwise I see water retention inside that notch.
