Water Leak though terrace
Old 05-30-14, 12:25 PM
L
Hello All
After the heavy downpour over the past couple of days I noticed a leak in the master bedroom coming though the terrace right above it. The spot on the terrace is where the water drains into the downspout. Seems like its getting into a crack or something and making its way down. Its not too bad yet but I wanted to fix it before it gets worse. The house was made in 2009 and has a membrane under the tiles so not sure where the water is coming from. Has anyone had this issue before ? Can this be fixed by buying some sealant at Home Depot or does it need professional attention ?
If can fix it by myself what sort of product should I get ?
First time home owner so I' am cautious and inexperienced.
Attaching some pics. Thanks !
Size:  13.1 KBName:  photo 2.jpg
Old 05-30-14, 08:45 PM
Received 1 Vote on 1 Post
what's the gap in the stucco's joint sealant ? IF i were you, i'd call someone,,, is the terrace used for anything ? its not so much the material as knowing where & how to install it correctly
