Ridge cap for quonset hut greenhouse
Received 0 Votes
I have an old greenhouse that I am rebuilding, and I want to install a lightweight ridge cap. It is sort of a Quonset hut, but the top isn't rounded over; it's pointed at about a 110 degree angle, if that makes sense. The north side is sheathed in plywood, and the south side has old corrugated fiberglass that I will be replacing one of these years. The length of the ridge cap will be 20 feet.
What I want to do is fabricate the cap using OSB or plywood, and then cover it with aluminum that I can buy in rolls that are 10 feet long and 12 inches wide. So I am looking for ideas on how to make the break in the aluminum so that it can fit the angle of the cap, or maybe even have it wrap around edges.
Also, if anyone has any innovative ideas on how to make the body, I'm all ears.
Why don't you just buy a galvanized metal ridge cap and screw it on?
Construction Metals Inc. 10 ft. Galvanized Steel Ridge Cap-RC2-GM at The Home Depot
