preventing corrosion metal siding
Old 07-23-14, 10:08 PM
What is the best way to finish the bottom of the sides of a building using 5v metal? The part I am concerned about is where the metal comes near the ground.
I thought about running a course or 2 of block, but I'm not sure that would solve anything with the metal being against the block.
Old 07-24-14, 03:51 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You are using 5v for siding? Not my first choice, but it happens. You can band the bottom of the building with 4/4 or 5/4 Miratec and allow your metal to rest on it, caulking it along the seam. As far as corrosion, 5v will eventually rust once the galvanization wears off, so just be aware.
Old 07-24-14, 04:18 AM
Received 741 Upvotes on 647 Posts
The best bet is to keep the metal siding off of the ground. When it starts to show signs of rust - prime and paint! Ideally, you'd prime/paint the yr before the rust shows up
Old 07-24-14, 06:34 AM
What would you prefer to use on the sides of a barn? 5v is the dominant material for barn sides around here..or so not seems. It is painted and not galvalume if that helps any. Good idea about the miratec. .thanks
Old 07-24-14, 08:16 AM
I've never seen the 5V crimp roofing come prefinished - Shop Union Corrugating 12-ft x 24-in 29-Gauge Plain Ribbed Steel Roof Panel at Lowes.com
Perhaps you mean this instead - Shop Union Corrugating 12-ft x 36-in 29-Gauge Plain Ribbed Steel Roof Panel at Lowes.com
V crimp comes in 2' widths, the other comes in 3' widths and can be had either unpainted or factory coated.
Old 07-24-14, 08:23 AM
You're right its not the 2' unfinishwd stuff...it's similar to the 2nd lino but with 5 ridges like the old 5v stuff...just assumed it was the same name I guess
Last edited by stickshift; 07-24-14 at 08:43 AM. Reason: Removed quoting of entire post
Old 07-24-14, 08:46 AM
It might be called the same ... I've never seen the 5 v crimp in 3' widths or factory finished. Unless they went with thicker steel I would expect that the wider panels would be kind of flimsy with no more bends in the metal to stiffen it up.
