Roofing Felt Paper Installed upside down..Does it matter?
Old 07-25-14, 11:22 AM
P
I finished installing #30 roofing felt paper on my 10x12 shed but after reading around it seems I put the wrong side up .. Meaning the lines that were marked on the felt are facing down instead of up. Seems like something minor but do i need to remove it and reinstall it?
Old 07-25-14, 11:38 AM
ray2047's Avatar
Except for the printing as far as I know both sides are identical. I always thought the lines were just cutting aids. Where/who told you there is a right and wrong side?
Old 07-25-14, 12:00 PM
P
I was reading here: Which Side of the Tar Paper Goes Toward the Wall? | eHow
but after re-reading they are talking about tar paper, might be different then felt paper
Old 07-25-14, 12:14 PM
ray2047's Avatar
Tar paper and roofing felt are the same. Actually walked out to the garage and my felt is not glossy on either side and while maybe a bit tacky when you unroll it I tested an old scrap and it wasn't tacky on either side but maybe I'm wrong. I can see sticky to seal seams... maybe but it never seemed sticky enough to do that. Maybe heat seals it but I doubt it.
Old 07-25-14, 12:29 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
That article is wrong about the sticky side stuff at least as far as I'm concerned. If that were true the rolls would stick together sitting on the pallet in the sun or during transport.
eHow isn't very reliable in my mind.
Old 07-25-14, 12:33 PM
P
When I was putting up it was very easy to walk on the side with no lines (spongy with grip). The sides with lines was more smooth. I figured it would be better if the spongy/sticky side was on the shingle side for better grip for the shingles. I just don't want to remove dozens of staples and possible damage the felt If I don't have to .
Old 07-25-14, 12:59 PM
Gunguy45's Avatar
Super Moderator
I wouldn't worry about it. The lines make it easier to run your shingles, but a chalk line is just as simple.
As to helping hold the shingles down, or the paper to the roof? Thats what the nails and weight of the shingles does. The only stuff that really adheres to the roof is ice and water membrane.
Old 07-25-14, 02:57 PM
P
Thanks. I'll just continue as planned and nail the shingles down
