Shingle Width question
Old 08-31-14, 06:10 AM
We have something called OAKRIDGE shingles.
In order to cover a 16" square, I am wondering how wide are the shingle sheets? Is one shingle sheet over 16"? How many nails per sheet are usually needed?
Old 08-31-14, 08:50 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Oakridge® Shingles featuring Artisan Colors | Owens Corning™ Roofing
Normally 4 nails per shingle. The specs in the above link explain everything.
Old 08-31-14, 09:35 AM
Ok, its says nominal size
13-1/4" x 39-3/8"
So im only familiar with the portion of a shingle you see on the roof installed. I assume there is about 6 inches exposed and another 6 that is under the overlapped piece on top of it.
And the entire sheet that comes off a bundle, before cutting it, would be the 39 3/8
WIDTH.
Be kind, Im not familiar with shingles.
Old 08-31-14, 10:20 AM
Gunguy45's Avatar
Super Moderator
Thats correct, about half is exposed.
Old 08-31-14, 11:49 AM
W
Received 60 Upvotes on 52 Posts
Exposure
Here are the instructions:
http://www.owenscorning.com/NetworkS...structions.pdf
Page 4 says 5 5/8 in. exposure. Hope this helps.
Old 08-31-14, 11:58 AM
XSleeper's Avatar
Received 1,701 Upvotes on 1,525 Posts
It's roughly a 5 3/8" exposure per row.
EDIT: I see wirepuller beat me to the punch.
Old 08-31-14, 12:01 PM
Gunguy45's Avatar
Super Moderator
Oops, says that in the specs I linked as well, didn't go back to check til now.
