Leak above exterior door
Old 10-11-14, 06:41 AM
D
Hi guys. I noticed a leak above my exterior door (on the inside of course) when it rained. The first time it happened I had leaves in my gutter, so I cleaned them out and thought all would be okay. It happened again today (it is raining) and the gutters are clear. i'm not sure with the rain heavier while I was sleeping and the gutters overflowed? But what else can I do in the meantime to check it out? Thanks
P.S. I'm attaching a pic to show the leak. It starts at the ceiling, where the ceiling and wall meet and drips down to the door header.
Old 10-11-14, 06:55 AM
D
Pic is sideways bc my mobile device uploaded this way...
Old 10-11-14, 06:58 AM
XSleeper's Avatar
Received 1,699 Upvotes on 1,524 Posts
I think we'd probably need a picture from the outside that shows the entire area.
Old 10-11-14, 07:02 AM
Received 1 Upvote on 1 Post
A picture of the inside is useless, need one outside.
Lack of shingle over hang, no storm and ice shield under the first few rows of shingles, shingles installed wrong, no drip edge, no Z moulding over the trim around the door, J moulding installed wrong, No window and door tape around the nailing fin if there is one.
Any of these can cause a leak like that.
But there all outside not inside.
Old 10-11-14, 07:32 AM
D
Sure. There seems to be an area of the roof, where water runs down like a "channel" or a river, which is directly above where I see the interior leak. You can see it in the pics I'm about to attach.
Old 10-11-14, 07:39 AM
D
I placed leaves in the area that looks like a "channel" where the water is running down.
Old 10-11-14, 08:04 AM
XSleeper's Avatar
Hard to say, but sometimes roof leaks occur a long distance from where the water finally shows up inside.
If the roof has a visible dip where the water seems to like to run, I would suspect that the problem is higher up, like maybe where the dormer corner post is. The flashing around dormers like that is often poor... and vinyl siding isn't a real good counterflashing.
It looks like there is a real dip in the roof as you get closer to that corner post. I guess I would wonder if the leak has been occurring for quite a while if the roof there is sagging.
Old 10-11-14, 08:40 AM
Received 740 Upvotes on 646 Posts
A pic from further back showing the door and the roof might also be helpful.
Old 10-11-14, 09:25 AM
D
Best pic I can get that shows the door and roof.
Old 10-11-14, 09:42 AM
XSleeper's Avatar
I'd start by taking off the vinyl siding on the left side of the dormer (not pictured) and maybe the bottom piece of siding under the dormer window. You will then be able to see what sort of flashing there is where the shingles meet the wall. I suspect that's where the problem lies... either no step flashing on each course of shingles along the side of the dormer... or a poor corner flashing behind the vinyl corner post. Or maybe it's the front wall flashing under the window. But being right below the corner of the dormer would make me suspect the side flashing or the corner flashing.
Old 10-11-14, 11:34 AM
Since you have a decent overhang over the door, the leak is probably on the roof or dormer as X has pointed out. Have you been on the roof to see if the dip in the roof is solid or weak?
Old 10-11-14, 09:25 PM
D
No, once it dries out I'll get up there. I'm thinking of cutting some of the Sheetrock ceiling out to look up in there to see if I can see where the water is running.
Old 10-12-14, 04:02 AM
If the drywall is in good shape - I'd save that as a last resort. As X stated earlier, water can travel a long ways down the framing before it decides to exit.
Old 10-14-14, 04:21 PM
D
The dip in the roof feels soft when I step on it. I was on the roof and it looks like the roof was installed over old cedar shakes and step flashing is missing as XSleeper suggested. Is this a simple fix?
Old 10-14-14, 04:57 PM
XSleeper's Avatar
If you just want to stop the leak, that's not too tough... like i mentioned, you would remove the vinyl siding and then flash the existing shingles.
But if the roof is soft its probably getting quite rotten under there. that would involve tearing off ALL the shingles in order to make the needed repairs. Might be more than ypu want to tackle.
Old 10-15-14, 03:28 AM
Just to clarify, the shingles don't necessarily don't need to be removed from the entire roof - just the affected area plus a little so new shingles can be laced in after the rotten plywood is replaced. The new shingles probably won't be a perfect match to the old
Old 10-15-14, 06:07 AM
XSleeper's Avatar
They should be able to weave in new step shingles without removing any shingles, by slipping the step shingle under the tabs... provided they aren't completely tarred down along the edges.
