foundation crack
Old 06-29-15, 12:36 PM
redsoxfan1's Avatar
foundation crack
Hi guys, so I have a crack foundation I want to use the flexible polyurethane grout injection kit and fix it from the inside.
My question is would it be OK to use it while is raining or should I wait for the rain to stop, it will rain for the next couple of days and if it rains hard it leaks.
I am thinking that if water is coming thru while I am applying the polyurethane it will not work properly what do u think.
Any help would be appreciated
Old 06-29-15, 02:41 PM
P
Temporarily Suspended
Waterproofing from the inside will fail sooner or later. Seal it from the outside with the proper membrane & you'll live happily ever after. It requires some digging but it's worth it.
Old 06-29-15, 06:43 PM
redsoxfan1's Avatar
Yeah i might have to, i did it once but I didn't want to dig this time, I have a back problem.
If it fails I will have to dig and do it from outside, they say this stuff is really good and will last.
But what about my question, I put the plastic ports today, I will put the mortar tomorrow and then injected with the polyurethane grout, hope it doesn't rain tonight or tomorrow
Old 06-30-15, 04:29 AM
P
If you want to take a chance, go head. It might work. You won't damage anything.
Old 07-02-15, 04:26 PM
P
Have you considered hydraulic cement? A little moisture should not effect installation, but it is honestly best to repair from the exterior
Old 07-04-15, 11:13 AM
Received 1 Upvote on 1 Post
seeing as you've got to flush out the crack in advance of injection, why wait ? we do that work professionally &, despite what others may think/post, its an accepted waterproofing method - even spec'd by state/fed dot's,,, i like hydrophyllic rather than hydrophobic for cracks leaking water,,, if it helps, i charge $600 for 8' vertical cracks - each just to show up w/material & seal 1 crack's min charge $ 800 why do i charge that ? the largest advertising wtrproofing co in town charges $ 1,200
ps - hydraulic's not a suitable material for this purpose nor is it as permanent as the method you've selected
