Valley end is nailed under stucco
Old 07-18-15, 05:06 PM
A
Received 1 Upvote on 1 Post
Hi,
I have a cement tile roof with a poorly installed valley that clogged and I need to put new felt under and around valley.
The valley is now loose but the end against a 2nd story wall seems to be nailed under the stucco. I can't detach it w/o cutting it and the lead flashing seems to done the same way.
It's only about 6' long and I can lift it up so I think I could easily slide the new felt under it. Is this acceptable?
Also, I immediately see why the valley clogged. The battens did not extend into the valley so the cement tiles just fell into the valley. I did a fair amount of research on valleys for cement roofs and the best approach seems to be the plastic batten extenders. Allows a lip on the edges of the valley, hold the tiles above the valley and allows debris to get through.
Thanks
Old 07-18-15, 05:39 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Can you post pictures so we can follow your project? We can't see what you see. http://www.doityourself.com/forum/el...your-post.html
Old 07-19-15, 09:47 AM
A
First picture is overall view, second is end at 2nd story wall. The valley is bent up and goes under the cap that attached to bottom edge of stucco so I assume it's under stucco and probably nailed to OSB sheathing. Same with the lead flashing.
I need to paint the house and do some minor stucco repairs this year but I don't know if there is a good reason to remove the valley from the house in one piece. If necessary I suppose I could cut it off as close to the house as possible and then re-install by nailing it as close to the house as possible.
Also, this raises another question. There are a couple areas with cracks in the lead flashing but again the flashing appears to be nailed to house sheathing. Perhaps for minor cracks a piece can be glued as a patch over the crack?
Thanks again
Size:  50.4 KBName:  valley2.jpg
