Mobile Home Addition Seam
Old 08-10-15, 09:33 PM
E
I need some suggestions how to repair the handywork that was done on this mobile. The roof is leaking at the seam in 3 places, The silicon was the last compound used I think. It isn't working.
Old 08-10-15, 09:55 PM
E
I was trying to delete the duplicate pics not getting it to work
Old 08-10-15, 10:38 PM
Received 3,412 Upvotes on 3,061 Posts
I can't help you much with your roofing issue but I did take care of your pictures.
Others will stop by and give you help.
Old 08-11-15, 12:04 AM
E
Thanks Pete for fixing my post
Old 08-11-15, 01:42 AM
E
One more picture ........
Old 08-11-15, 01:47 AM
E
added another picture .......
Old 08-11-15, 03:47 AM
Received 740 Upvotes on 646 Posts
I couldn't tell from the pics, how was the addition's roof connected to the MH? is there flashing connecting the two?
Old 08-11-15, 01:55 PM
E
I do not think flashing was used.Most of the outside wall was removed. there is a header between the sections.
Old 08-11-15, 02:26 PM
Without flashing, leaks will be an ongoing issue. Flashing can be difficult to install once all the 'goop' has been put in the way. I'd probably try to remove the tar/caulk and see if I could install flashing. .... but I'm just a painter [have built MH additions for self/family/friends] maybe the roofers will have a better solution.
Old 08-11-15, 03:26 PM
E
Received 3 Upvotes on 3 Posts
I'm not a roof guy but what I've done at a rental property is to use a roll of aluminum backed self adhesive bituminous memebrane over the seam. Worked for me.
Old 08-11-15, 04:23 PM
Received 125 Upvotes on 110 Posts
This is going to be nothing but an ongoing issue.
No way would I have used rolled roofing on that low slope roof, a one piece membraine roof and proper flasing would have been good for at least 20 years.
Blobbing more caulking of a different type and not even leveling it off is never going to work and just form a dam for water to run in.
Adding any form of tape over that messed up seam is also never going to work.
Sorry but all that old sealer needs to come off and flashing added.
Old 08-11-15, 06:30 PM
ray2047's Avatar
Agree 100 %. A lot of work but the only way unless you build a roof with independent support posts over every thing. Not really making the second suggestion but I have seen it done by a commercial metal building company and it looked nice.
Old 08-11-15, 11:34 PM
E
I suggested to the lender (foreclosed property ) that all the gook would have to be removed, They want a quote for repairs, they wont go for time and materials
