How far a gutter should go off the roof?
Old 08-21-15, 09:00 PM
T
Old 08-21-15, 09:33 PM
B
Received 37 Votes on 34 Posts
Hi Tito,
The general recommendation is about 10 feet, however, the distance is related to the slope of the ground around your home, all the way to where that water will no longer be a concern. It would do no good to grain the roof 10 feet away if that water simply drained back towards the house.
On the other hand, if you have a really good slope, 3 or 4 feet might be fine.
The process starts with the landscaping. One of the difficulties some homes run into is the surface drainage may slope away from the house while the ledge or a layer of clay below the surface slopes back to the foundation.
Over time the disturbed soil next to the foundation will settle and create a drainage point for water right next to the area where you don't want it.
Bud
Old 08-21-15, 09:43 PM
T
Sorry I did not wrote right. I mean how far the gutter should be off the Ledge of the shingles.
Old 08-21-15, 09:55 PM
B
10' would be a little difficult . Very few homes here in Maine actually use gutters so I rarely deal with them. I'll let the others answer for you. But where that water goes is still important.
Bud
Old 08-22-15, 03:26 AM
chandler's Avatar
Received 5 Votes on 5 Posts
It's not so much where the gutter goes, as it is attached directly to the fascia board. The shingles are placed to where they run about an inch into the gutter space. Fill us in on your problem.
Old 08-22-15, 09:35 AM
T
The problem i'ts Georgia have alot of rain. I see other gutters around the house have different distance where the gutter stick out.
Old 08-22-15, 10:04 AM
chandler's Avatar
Can you post a picture of what you see? Gutters follow the fascia board. The roof may have been put on incorrectly, or the roofer over extended his roofing material. http://www.doityourself.com/forum/el...your-post.html
Yes we have had quite a bit of rain lately, especially up north.
Old 08-22-15, 11:40 AM
Received 291 Votes on 259 Posts
Are you referring to the downspout? I've seen a few that just have a down turn without actually going all the way to the ground. The further the rain water is diverted from the house the better!
Old 08-22-15, 12:17 PM
Received 1,019 Votes on 946 Posts
I think he meant to say is how far down should the gutter be mounted under the roofing edge.
Old 08-22-15, 02:37 PM
Norm201's Avatar
Received 225 Votes on 200 Posts
If PJ is correct, then one end should be pretty much up to the very edge of roof while the other end slops down. The opposite end may be as low as 2 to 3 inches depending on the length of gutter and roof. The other question is if he meant how far show the gutter extend from the end of a roof edge if it does not wrap around a corner.
Old 08-23-15, 06:05 PM
T
ya that is what I meant. Sorry for my English, it's French that is easier for me.
Old 08-23-15, 10:29 PM
F
Received 35 Votes on 27 Posts
Whatever happened to French277, the electrician that commuted between France and (I think) Minnesota?
Old 08-24-15, 03:31 AM
Norm201's Avatar
tito,
So which is it? What PJ suggested or what I suggested? We're still confused.
