Water under fondation?
Old 08-22-15, 05:08 AM
My house have some holes in ground next to fondation, I believe there is water undder. we bought the house rescently, there is mold and removing sheet rock we found at bottom wet 2x4. I fixed the gutter that was detached that probably created the hole. My house is elevated at that side and there is a slope right next to it, how to drain water from under the slab?
Old 08-22-15, 05:25 AM
Received 167 Votes on 148 Posts
Short of digging down and pumping out the water I doubt there is much you can do but if the source of the water is gone - it will dry up on it's own. I assume no basement ?
Old 08-22-15, 05:56 AM
Yes there is a basement, water damage was in basement.
Old 08-22-15, 06:01 AM
Then there is more going on than just the water not being diverted from the foundation. You need to inspect the foundation wall for cracks/holes. Waterproofing is always best addressed from the exterior! but that does involve a good bit of digging Don't close the interior walls back up until you know the water problem has been fixed!
