Sill Plate Drip edge flashing
Old 11-13-15, 09:49 AM
I'm building a barn, and need some sort of flashing like the following picture depicts:
While I'm not required to have termite protection, with how the foundation is made a continuous run of flashing like the "Metal termite shield" shown would be ideal to install.
Some questions:
1) If I sandwich it between two sill gaskets, does it matter whether I use aluminum, copper, or galvanized? I'd prefer something that won't rust - so this leaves copper or aluminum. Copper is... expensive and overkill. But, if it will outlast aluminum (treated sill plate, poured concrete foundation wall) I'd go with it.
2) Can I bend this myself? I basically need a straight piece of flashing with a 45 degree bend on one end. I've looked at techniques online, but I want a clean appearance. I don't know where to get this locally (Home Depot? Lowes? Gutter company?).
3) How much do I overlap the ends and do I use a silicone product to seal the flashing to itself?
Total linear feet - 110.
Thanks!
John
Old 11-13-15, 10:30 AM
Received 131 Votes on 117 Posts
If I'm not mistaken, PT wood will corrode aluminum although a strip of tar paper or sill gasket should protect it from the PT.
Old 11-13-15, 10:49 AM
XSleeper's Avatar
Received 216 Votes on 201 Posts
While the flashing is nice as drawn, the sheathing and siding usually hang over the foundation 1", making the flashing unnecessary.
Old 11-13-15, 11:57 AM
Regarding the flashing, that up-bend in the flashing "supposedly" makes it difficult for termites to climb over it.
