Repair roof shingle color match to the old shingles
Old 04-20-16, 08:56 PM
A
aro
aro is offline
I have a roofer coming over to fix the wall flashing and install the kick out flashing where needed. He recommended to replace the shingles around the wall. He said that Home Depot or Lowes carry shingles and colors will be close enough or identical. Should I be concerned that shingle will not match and repaired area will stand out? What are you guys doing in situations like this? The current roof was replace on 2008.
Name:  The wall flashing 1.JPG
Name:  The wall flashing 2.jpg
Old 04-20-16, 09:01 PM
XSleeper's Avatar
Received 939 Votes on 857 Posts
Replaced shingles will not match exactly. The sun has been fading yours for 9 yrs. Sometimes even a different lot/ batch of shingles made the same year won't match. I don't know why he would need to replace shingles to fix that flashing. Any careful roofer could do it without damaging them.
Old 04-21-16, 04:32 AM
P
Received 902 Votes on 830 Posts
You should consider yourself lucky if they can find shingles that match well enough to not be noticeable. Even new shingles from batch to batch vary and I've even seen roofs with lines or zones of color variation where the color changes throughout the production run. Add in 8 or 9 years fading and the chances for a match diminish even further. But... you may not have an option. If your existing shingles are damaged trying to remove them to do the flashing you have to put shingles back on the roof somehow. Obviously saving as many of the old shingles would be the best cosmetically but it can require a careful hand which slows down the work.
Old 04-21-16, 06:23 AM
Received 102 Votes on 89 Posts
Some of the newer dimensional shingles I've tried to remove to do a simple repair job where stuck together so tight that even a flat bar and a hammer would not get them apart.
Looks like the same roofer that install your "sort of flashing" also did all the roofs in my area, including mine until I changed it.
Must have been a sale on aluminum foil at the grocery store
